Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rebuilt 327 issues
Old 07-03-2010, 08:57 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
What transmission? Stall converter? What do you mean by the timing is "all over the place" The timing should be set around 16 to 18 degrees base with that much cam and the full advance 3000 RPM and up should be 38 degrees.
What`s the fuel pressure? are the floats set correctly? what`s the compression ratio?
