Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rebuilt 327 issues
Old 07-10-2010, 09:36 PM
lg1969's Avatar
lg1969 lg1969 is offline
Google "Tunnel Ram 406"
You should check if the float is closing properly or the float level is too high.
If both carbs were leaking then you may have high fuel presure. It should be 5 psi. In this case, you only have one carb that is leaking.
