Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rebuilt 327 smokes - what to do
Old 10-10-2001, 06:00 AM
Tom Tom is offline
drain the oil and put in some non detergent straight 30 or 40 weight start the engine run it up to 3000 rpm and let it run there for about 45 miniuts and see if the rings will seat(I am assuming this is the first time your running it after the rebuild) if it doesen't stop smoking check the valve seals
