Did you do the build??? Need some history here...
Sam
I didn't do the rebuild. It was professionally done. I do know he installed umbrella seals. I'm assuming once the engine is up to normal running temperature, its just burning all the feud from the cat, back. Inside my tail pipes are thick of black crud.
oil burning
I had a similar situation with my 357 sbc using an aluminum intake on iron 041heads and felpro intake gasket set. When my engine got hot and then cooled the intake swelling from the heat would literaly tear the gasket allowing oil to leak into the combustion chamber. I know it sounds funky but after installing new intake gaskets that have metal in them the tearing stopped and thus the oil burning. The heat must also be dealt with asap. Mine smoked noticably and was freaking me out with all the dough I spent meticulously assembling my motor. I thought I knew everything but this was a learning lesson for me! I will find the part # of the gasket set that only cost $10 from my machine shop here in Portland and post it as soon as I can. Cortect I think is the MFG? Timing can effect the overheating also, you might want to confirm you are where it should be for your cam. I run at 11 degrees and added a cross flow aluminum radiator that cured my problems. 400hp, th400 (chirpomatic), 373 10 bolt open gear (crash prevention). Posi coming though! Hope this helps.
Also, since the car had a v6 stock, I'm assuming the radiator and fan cant support enough cooling for my current 350 5.7? Gonna be driving in a week so I would like to have this all squared away.
YES, you need a V8 cooling system.
Are you just letting the car sit and idle until it gets Hot? You should at least have a house or shop fan blowing across the radiator. Before you start swapping parts, check the timing, pull the plugs and inspect them. Also do a compression test to check the condition of the motor. Report back and we'll help from there. |
Will be replacing the intake manifold gaskets with edelbrocks. I will let everyone know how it turns out. In the meantime, Amy suggestions on what to do about the engine running hot would be appreciated. I let all the air out of the system yesterday, which didn't make a difference.
| 350 chevy engine burning oil | buick66 | Engine | 8 | 11-17-2011 11:53 PM |
| Rebuilt 350 oil pressure woes... | jb88ci | Engine | 9 | 04-22-2011 11:38 AM |
| 383 engine tapping and oil burning- weird | RowShan | Engine | 15 | 10-10-2009 05:07 PM |
| Oil to lifters in rebuilt 350 | 2lo50 | Engine | 25 | 08-09-2006 03:36 PM |
| rebuilt engine no oil pressure in oil galley | bmedina103 | Engine | 9 | 10-07-2002 10:37 PM |
