IF it is hard to rotate by hand..........STOP Remove the spark plugs and try it again.......... If it is still difficult to rotate............you have a problem with the engine. SORRY....... .
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
Rloban,
Deuce is right! Do not force it to turn! Once I had a student drop a washer in the intake and when we went to start the engine it froze. Pull the plugs and see if it turns. Good Luck Scholman |
Did the person who rebuilt it leave the Plasti-Gage in place instead of removing it after checking the clearances?
Could be any number of things from rods installed backwards to improper (too tight/interference fit) clearances. Start by popping the oil pan and loosening parts until it turns......
Ive always found freshly rebuilt engines tight to turn by hand (spanner) and usually u hear the air being squeezed through rings. As the other chaps said, with the plugs out give it a crank to see what happens. But if it's frozen then there' a prob. There's a possibility that the torque converter popped out of the trans slightly and may have become misaligned with the pump tangs. This would cause the torque converter to get sandwiched hard between the flywheel and the transmission pump - the engine would not be able to turn as a result. If you think this is a possible senario for you, ie. you're not sure if the t/c is free, then it would be a lot easier to check than dropping the sump. All you'd have to do is loosen the bellhousing bolts and see if the engine becomes free. You'd know as u undo the bolts if there's a prob - cause if there is, then they'd be tight to undo untill the t/c is not crushed any more. When doing up bell housing bolts, you should have the bell housing pushed hard against the block before you start tightening the bolts......or at least see if the bell housing is able to kiss the block with ease. Then u'd know you're in business. Hope you're doing okay. Rob
Man I must of drank too much last night....really I was drinking.
Definitely look into loosening the bellhousing bolts a little like club 327 said before tearing into the motor. The convertor might not be properly engaged in the pump slots binding everything up. Sorry
Kevin |
I got around to checking it out and the main bearings were completely dry no oil or lube whatsoever!!! I put some white lithium grease on them just to see if it would turn and it did. I was able to turn it with about 40ft pounds on the torque wrench. But I took out the crank and brought to the machine shop to have the journals checked and I'm gonna get new bearings just to be safe.......
