Rebuilt 350 oil pressure woes...
hey all...new to the forum cuz i was searching oil pressure woes...
I had a 350 rebuilt and received it as a short block. New high volume pump etc. It has a remote filter and i'm priming it with a modified distributor. After 2 X 20 minute attempts, spinning the pump extension shaft clockwise, I'm not getting any oil to the OPSU or top end at all, it is getting a tonne of pressure at the filter (i pulled filter and gave the drill a spin). I dropped a welding rod into the opsu passage to see if that plug was in there. I read that if you measure 8.5" or less, plug is in. I got 8.5 exactly. I'm scratching my head here...any ideas? John |
I got a junk dist, took the 'gear' off the end, put it in a lathe and took the helical teeth off so that it won't turn the cam. Its modified distributor...and its not getting wet in the least either.
I can feel the resistance of the pump when i spin it with the drill, oil shot out the filter line when i yanked the filter. |
Remote Filter |
It needs to spin the pump pretty quick. If it's a HYD cammed engine, spin I over once after you run the primer for a while. This will get the lifters to change position on the lobe and allow them topinkp up. Oil restrictors also could cause long prime times initially.
Yep.... Hoses were backwards ... Switched them at the filter an in seconds I had pressure at the opsu and a minute up to the rockers. Thanks for the help..
| oil pressure problem on rebuilt 1978 350 | grigorma | Engine | 2 | 04-26-2005 04:40 PM |
| Low oil pressure at idle on rebuilt 350 | Palmtrees57 | Engine | 25 | 02-13-2004 10:30 AM |
| rebuilt engine..fuel pressure very low? | 79454 | Engine | 7 | 10-06-2003 12:20 PM |
| oil pressure woes....... | onebadmerc | Engine | 5 | 03-13-2003 06:54 PM |
| rebuilt engine no oil pressure in oil galley | bmedina103 | Engine | 9 | 10-07-2002 10:37 PM |
