Rebuilt 350 Olds makes clapping noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2009, 10:09 PM
My motor is making a clapping noise under load and upon acceleration.
I have a freshly rebuilt 350 Olds engine that I finally got running this summer. Engine was built a couple years ago and car has only been driven once since rebuilt engine was installed. Unfortunately, upon dropping the motor in the car and starting the car, I detected a very noticeable clapping/tapping sound coming from the motor. This is not an engine-knock, it is almost like a loud rattle sound.
The motor is a 1970 Olds 350ci bored 0.060-over. It was rebuilt to stock specs along with an aftermarket cam. It has a 10.25:1 compression ratio. Timing is at 12 degrees TDC.
I have eliminated this noise coming from any belt-driven accessories (power steering, water pump, alternator, fan) and basically any other external motor parts. I have also changed carbs, distributor, gas, oil, used colder spark plugs, in hope of fixing the problem.
I had a mechanic come look at it and he said the noise was coming from behind the timing plate cover. I checked this out and everything checked out OK.
Anyone have any ideas?
Old 12-01-2009, 11:43 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
Could be a wiped out camshaft. Take the valve covers off and check for a lose rocker.
Old 12-02-2009, 04:12 PM
I already checked under both valve covers. All the rockers were tightened to spec. Nothing looked unusual under there.
Old 12-02-2009, 04:22 PM
SUX 2BU's Avatar
I had loose torque converter to flexplate bolts and it was a very loud rattling sound at idle. Went away as RPM's came up.
Old 12-02-2009, 04:42 PM
That is something I thought of too. However, I checked those bolts last time I worked on the car and they were all tight.
The noise is barely noticeable at idle, but most audible when the engine is revved up. I noticed that when retarding the timing and giving it gas, it really creates a loud-pitched rattle/tapping noise. Its really hard to tell where exactly the noise is coming from though.
Olds 350 Heads ! TommyV_11 Engine 5 12-04-2009 05:48 PM
403 olds big block versus 350 target master rebuild dustin.campbell3 Engine 18 08-26-2009 06:12 PM
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 12:44 AM
1991 olds 88 noise and cam sensor fumplet Engine 0 08-04-2007 11:51 PM
My 231ci Makes Noise When I Accelerate 7skylark6 Engine 18 12-28-2003 09:53 PM
