Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rebuilt 350 won't start
Old 07-05-2011, 05:52 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
If it still won;t start after correcting the distributor, check each cylinder for compression. Remove all the spark plugs and kick it over with you thumb over the spark plug holes of each cylinder If any lack a strong compression push
the valves- rocker arms on that cylinder are adjusted too tight and the valves are always open. (no cylinder compression) If so loosen and reset the rocker arms using the up down method on the pushrods instead of the spin method to feel the 0 lash point.
