e boseze
another fella & I rebuilt '60s ford bus for a church in mexico with mex. parts would not run.... finaly tore it down and sure'enuf timing mark was 180 off. pulled it and had about the same air pressure fron carb as exhaust.... fun tho!
lol |
All of the things you mentioned are possibilities. It is time to eliminate things one at a time. I would start with the valve adjustment. Valves that are too tight can cause all kinds of issues and eventually can cause permanent mechanical damage. If eliminate things one at a time you will find the issue. There are several threads here on adjusting valves properly. Search for one and follow the procedure and see how it runs after that.
Artificial Intelligence is no match for Natural Stupidity Chet |
Readjusted valves. Engine is getting a little better. Stays running a little longer but idle is still very rough. I noticed some smoke coming out where the intake mates to the head. I think the gasket might not be sealing. If so would this cause a rough idle? Will try and get to this tomorrow.
rough idle
a slipped gasket thats leaking will give u a idle problem.. very lean in a few cyl's. looks like u really need to pull it and replace it. try some rtv blue around the intake/head areas, just put some one a smear it around with your finger,don't need alot.
bad idle
for a quickie, u can move all your plug wire one slot in the direction u move the dizzy and that will give u more movement to play with.. u can leave them there or pull the dizzy and reinsert to alin again.
Wouldn’t / Couldn’t you pull the number 1 plug and use a piston stopper / feeler to get the piston to TDC and then check make sure the distributer rotor is also pointing at the number 1 position?
So I moved the plug wires one terminal counter clockwise and engine started up. I had to keep on giving it the gas to keep it running. if I let off the gas the engine dies. Is this now an idle problem with the carb? Can I leave the plug wires like this or do you recommend me to retime it?
Other than improper assembly such as your intake gasket mis-alignment, I suspect you may have a cam timing or valve adjustment issue. I suggest the following: (For a stock/mild aftermarket duration/lift hydraulic cam profile engine only) 1- Remove valve covers, loosen all rocker arms past ".000" clearance, and remove #1 spark plug. 2- Insert a long thin object such as a drinking straw (or screwdriver if you be carefull) into the #1 spark plug hole in order to monitor #1 piston physical position within the cylinder. 3- While keeping the straw/screwdriver from binding within the motor, manually turn crankshaft in the normal operating direction (CW viewing from the front-to-rear) until #1 piston is at top dead center after exhaust stoke. At this exact point, the #1 exhaust valve should have just closed and #1 intake valve just starts to open)(The term for this position will be referred to as "rocking" for the remainder of these instructions). Note: When locating the #1 piston to top dead center, if the piston is at top dead center on compression stroke the rocker arms will not be "rocking" and you'll need to rotate the crankshaft another full turn (360 degrees) in order to get the rocker arms in the correct position. Important!!! The exhaust valve should have just finished closing and the intake valve just starting to open when the piston is at exactly top dead center. If not, your camshaft timing is set incorrectly. If cam timing is correct, set the distributor rotor position to exactly 180 degrees opposite of #1 plug wire position and temporarily tighten the distributor (which will now have the rotor pointing to #6 on the distributor cap (for your 350 small block chevy motor) 4- Adjust #6 intake and exhaust rocker arms to "0" clearance + 1/4 turn for hydraulic lifters. 5- Next: Looking at #8 rocker arms, turn crankshaft until #8 exhaust valve just closes and #8 intake valve starts to open (rocking). At this point, adjust #5 rocker arms to "0" clearance + 1/4 turn. 6- Next: Looking at #4 rocker arms, turn crankshaft until #4 exhaust valve just closes and #4 intake valve starts to open (rocking). At this point adjust #7 rocker arms. 7- Same procedure with #3 rocker arms "rocking" and adjust #2 rocker arms 8- #6 rocker arms rocking, adjust #1 rocker arms 9- #5 rocker arms rocking, adjust #8 rocker arms 10- #7 rocker arms rocking, adjust #4 rocker arms 11- #2 rocker arms rocking, adjust #3 rocker arms 12- Now you'll need to loosen the distributor housing and turn '~10' degrees counter clockwise in order for the base timing to be close to spec. (a timing light may be needed to set correct base timing later according to specs for your motor/application). 13- Replace valve covers and re-install #1 spark plug 14- Crank the engine and run at ~ 1500-2000 RPM until hydraulic lifters adjust. (the motor may miss or the valve train may rattle (or both) upon start-up until the lifters adjust. Give it ~ 1-2 minutes for this to take place). Hope this helps. Mike |
| New Rebuilt Motor Will Not "Start | newdad1 | Electrical | 8 | 03-29-2009 09:13 PM |
| Need help getting rebuilt sb to start. | mouseman | Engine | 26 | 07-09-2006 07:04 PM |
| Carb rebuilt but won't start now.... | ecrusch1987 | Engine | 4 | 11-10-2004 07:56 AM |
| Rebuilt engine won't start | bjam2 | Engine | 5 | 10-09-2003 05:01 PM |
| I want to start my rebuilt 350 but can't!!! | zeeman19 | Engine | 2 | 07-05-2002 09:40 AM |
