Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rebuilt 4L60E problems
Old 08-20-2011, 08:25 PM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
if you have to shift to manual "1" to get the vehicle moving from a full stop , you have a low roller clutch problem. The low - reverse clutch comes on in manual "1" and the vehicle moves from a stop
The design of the aluminum drum piston seals... the forward and over run ports will bleed between as you experience.
