Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rebuilt 700r4 No moving
Old 05-16-2013, 07:14 AM
dogwater dogwater is offline
Last journal entry: Still running strong
When I rebuild mine I kind of had it in my mind that I'd have to pull it out agine, and I did. I only had reverse. Pulled it out an took it apart to the first & reverse clutchs , ended up some dumb *** (me) didn't put the sun gear in. One thing you can do is get a brass elbow with male threads 1/8 pt. An screw one end into the port an get a threaded cap w/o-ring an put the cap on, then if you need to pressure test agine its easier to get to.
