Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rebuilt Chevy 350 break-in issues
Old 09-19-2013, 05:10 PM
bygddy bygddy is offline
Proud LOSER
And last but not least, the "spinning" the pushrod method almost always results in exsessive lash. Its not as easy as it sounds.
Use the jiggle up and down method, its going to be more accurate in your case.
A little loose is better then a lot tight.....it can be reset after cam break in.
