Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rebuilt Chevy 350 break-in issues
Old 09-23-2013, 07:39 AM
Davect06607 Davect06607 is offline
Originally Posted by bygddy View Post
And last but not least, the "spinning" the pushrod method almost always results in exsessive lash. Its not as easy as it sounds.
Use the jiggle up and down method, its going to be more accurate in your case.
A little loose is better then a lot can be reset after cam break in.
Ya I made this mistake the first time around, had no compression in the engine, when cranking by hand. All the valves was too tight.
