rebuilt chevy 350 help - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2008, 03:16 PM
I have a 350 chevy that I did a top end job on. It's a 1976 4bolt, stock pistons and crank (in excellent shape). I put it in my 66 chevelle and have been working on it but it runs like crap when I push it (bogs when I hit the gas hard and after it finally picks up, it loses pull at higher rpms). I am getting nowhere near the performance I should be getting.
Heres whats in it:
- completely rebuilt heads - 60cc, 2.02 intake, 1.60 exhaust.
- comp cam xtreme energy 274 cam, .490 lift intake and exhaust, tappet
lift 274
- new comp cam hydraulic lifters
- edelbrock performer manifold
- edelbrock 750 cfm 4 barrel carb
- on the rebuild, new, high performance oil pump, fuel pump (mech), water
pump, radiator, gaskets,seals , etc.
- rebuilt saginaw 4 speed trans
- new points distributor, and high energy coil
dwell is set at 30 degrees and timing is set at 4 degree BTDC
Despite all this - it runs like crap - HELP!
Old 05-30-2008, 03:39 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Timeing should be 10-12 degrees before TDC.
Old 05-30-2008, 06:31 PM
techinspector1's Avatar
Wiki Edits: 326
You'll run out of camshaft way before you run out of carburetor. A 600 would have done it. Anyway, try to tune it for the motor as best you can.....
http://www.edelbrock.com/automotive_...ers_manual.pdf
buick 350 - chevy 350 72buick Engine 23 10-13-2009 09:38 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 04:45 PM
Need suggestions on building up a 350 Chevy JAKE 68 GMC Engine 15 02-06-2007 06:26 PM
Putting chevy 350 in 74 Plymouth Duster mouseman Engine 2 08-27-2006 05:56 PM
350 buick in chevy truck? jrm123180 Engine 7 04-04-2004 12:03 AM
