-   -   Rebuilt engine question (http://www.hotrodders.com/forum/rebuilt-engine-question-221316.html)
kingofny1997 07-05-2012 07:49 AM
Whats up hotRod, just wanted to know I rebuilt the top end of the motor, and have everything installed, new oil and battery connected is all that's needed,
I have valvoline vr1 as my oil, do I have to put ENGINE BREAK-in OIL additive, since vr1 has zzdp (racing oil)??? Also how much oil should I put in???
DanTwoLakes 07-05-2012 08:01 AM
Moving this to Engine.
Dan
1971BB427 07-05-2012 10:06 AM
Hard to say with so little info. What engine? Just heads, or new cam too, and is it flat tappet or roller cam?
engineczar 07-05-2012 10:12 AM
If a new cam and lifters were included in the build I would use the additive. If not then the vr1 will be fine.
The amount of oil depends on what oil pan you have.
1971BB427 07-07-2012 03:47 PM
Can't always go by what comes with a cam kit. I've had a couple that the maker left the lube out o, and when I called them they sent it separately.
cobalt327 07-07-2012 09:51 PM
Here is a page on the subject. If you have questions after looking it over, just ask.
