Rebuilt Engine Smoking
I recently rebuilt a sbc 350 engine. Its just a stock rebuild w/ rebuilt 350 heads, edelbrock intake, & a new edelbrock 600 cfm carb. The problem is that I'm getting a grayish smoke coming out of both tail pipes (it has true dual exhaust). I've adjusted the rockers several times, reset the timing multiple times, adjusted the carb multiple times & I'm still getting smoke out of the pipes. Does anyone have any idea on what my problem could be???
check your pcv might be sucking oil to carb. this same thing happen to 1971 nova drove me crazy
Never would've thought about that.....thanks dude
also pcv must be baffled if you have stud gert you will have to get baffled groument tall valve cover with baffle would not fit because of stud gert
you totally lost me on that Nova....the pcv valve that I'm using is just a stock one from autozone & I am using a rubber groumet....w/ chrome edelbrock valve covers.
you should be fine then as long as you hear ball when you shake pcv
just plug the big vacuum port thats in the middle of the carb and see if the smokes stops, lets the engine run for a minute or 2 if not well that wasn't your problem |
| Rebuilt TBI 350 black smoking, running rough | scarecr0w | Engine | 7 | 09-08-2011 02:51 PM |
| rebuilt engine smoking question | the dan | Engine | 3 | 09-25-2007 09:37 PM |
| new engine is smoking | potts | Engine | 7 | 04-04-2006 02:27 PM |
| smoking engine | carguytrg | Engine | 3 | 01-02-2005 12:52 PM |
| New rebuilt 350 smoking when changing gears? | shockers69 | Engine | 9 | 01-17-2004 07:08 PM |
