rebuilt engine smoking question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2007, 02:48 PM
the dan's Avatar
83 chevy c10 long bed
so i rebuilt my 350 back in november, and put it in the truck in may, ran it for a month and blew up 2 tranny's, got it running sept 2nd and noticed it smoked a little, didnt fase me thaught maybe it was still bearking in,
now the smoke is getting bad, a quart every 16gallon tank,
Problem:
when i first got it running i took it down the road, kept an eye on all my gauges, and without my knowledge it overheated and seized the pistons to the cylinder walls (gauge stuck at 180), cooled down and started back up but it was due to a faulty thermostat, could the aluminum have scored the cylinder walls and basically wrecked everything? or could i be lucky and just have bad valve seals (vortec heads, replaced in rebuild)?
its just making me pretty frustrated spending about 2 grand building an engine to it burning alot of oil
Old 09-24-2007, 03:03 PM
DoubleVision's Avatar
If it ran real hot chances are the rings overheated and lost there tension. I would put a vacuum gauge to it and see how much the needle moves. Chances are it ran so hot it seized, the rings are likely gone. The pistons and the cylinder wall likely don`t look so good either. You may also run a compression check and see what you get cylinder to cylinder. My guess is it`s rebuild time.
Jmark's Avatar
If it got hot enough to stop running, serious damage did occure. Time for a pull down. check everything.
Mark
Old 09-25-2007, 10:37 PM
the dan's Avatar
thanks thats what i was affraid of
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 06:22 AM
Valve Lash adjustment hiball Engine 36 05-11-2009 11:12 AM
Another Engine Swap Question 7skylark6 Engine 5 02-06-2004 02:17 PM
Hotrodders Guidelines -- READ ME Jon Hotrodders Site Suggestions and Help 0 06-14-2003 06:07 PM
