Artificial Intelligence is no match for Natural Stupidity Chet |
The stock jetting on that carb calls for a 66. I would go back to that size. Generally the stock sizes are pretty close. Rarely do they ever need more than one or two sizes from what Holley puts in them from the factory.
BSE Racing Engines |
The power valve rating is about 1/2 of the idle vacuum IN GEAR if it's an automatic, neutral if it's a stick. For your 12-13 in/Hg vacuum in gear, the 6.5 PV is perfect.
Why did you change the jetting 4 numbers? I, too, would go back to the stock jetting. Baseline it, then start playing around w/more or less jetting. You'll need to run it at the track to know whether you're making a change in performance for the better or not. If economy is your main concern instead of performance, you can go by the seat of your pants along w/the color of the plugs. But just dropping 4 numbers for no reason isn't how it's done. In any event, I suspect the stock jetting will be closer to correct than 4 numbers smaller than stock. The bog when you punch it could be accelerator pump-related or the secondaries opening too soon. Is the timing curve sorted out correctly? |
I jetted down because the plugs were reading rich. I didn't go down 4 holley sizes, just two, as they come only in even numbers.
From what I've read online, Holley recommends that you check your idle vacuum while in gear, and then take two off that number for your power valve size. That way, its activating quickly on part-throttle acceleration. I realize the stock jetting is 66, but this carb is already "big" for a 307 I figured. I switched to a 64 and an 8.5 power valve, and so far it's much better.
Bringing history and technology together. |
Gasoline main JETS are available in even AND odd numbers. The numbers do not necessarily equate to the orifice size in thousandths of an inch, either. You went down 4 numbers and IMO that was too far- that's the MAIN point. Quote:
While Holley has posted somewhat conflicting info regarding PV sizing, the "couple numbers less than idle vac. in gear" is not usually what is used for a mild street engine such as yours. The reason you wouldn't necessarily want the 8.5 PV in there, is because you're getting enrichment almost every time you accelerate- remember, the PV opens at the vacuum rating, so each time the carb "sees" 8.5 in/Hg or less, it's at full enrichment. Yet another way to size the PV if you don’t want to use the common “1/2 the idle vacuum in gear”, is to mount a vacuum gauge that can be safely seen while you drive under various conditions and select the PV number by going w/a PV 2 in/Hg below the lowest steady speed engine vacuum observed. Quote:
| Rebuilt holley dp won't idle | D9ZZ | Engine | 3 | 04-19-2009 09:56 PM |
| Car seems to be 'surging'.... | 64 Impala SS 96 | Engine | 15 | 05-05-2008 11:06 AM |
| surging | badknuckles | Engine | 8 | 12-23-2005 06:49 AM |
| Holley "Blue" rebuilt as a "Red" pump | lluciano77 | Engine | 3 | 05-17-2005 08:41 PM |
| Uneven response, light surging holley setup | killerformula | Engine | 18 | 12-03-2004 09:11 AM |
