rebuilt lt1 wont stay runing on its own - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2012, 12:58 PM
i have just rebuilt my lt1 with forged bottom end .030 over lt4 hot cam lt1 preformer heads edelbroke intake 58mm throtle body 38lbs injectors no egr to i started the car did a cam break in and it will not idel on its own do i have to get the pcm tuned oh and the fans stay on the entire time its running with no relay in it idk where to go from here cam someone point me in the right direction
Old 07-22-2012, 02:40 PM
The tuning is done within the pcm. Way overkill going with 38lb injectors. There is no such thing as cam break-in when you run a roller camshaft. They don't need any break-in. You can safely run the stock injectors up to around 425hp, and you won't hit that number with those parts.
Try pcmforless.com . You can send them your computer, they will reflash it (tune) and send it back to you, or you can purchase a computer directly from them. If the fans are on the entire time, it should have a check engine code being displayed.
car wont stay runing ibad83box Engine 3 01-14-2012 08:37 AM
T-400 wont stay in third robbie thoreson Transmission - Rearend 17 09-27-2011 09:46 AM
rebuilt small block wont stay running Linez35 Engine 6 09-06-2011 03:55 PM
53 chevy pickup wont stay runing orillionro86 Engine 8 08-16-2011 05:21 PM
