Rebuilt Manual Transmission Won't Shift Into Any Gear? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-15-2011, 07:33 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Originally Posted by RichieB
BTW, here's a pic of the trans installed...
Glad to hear you got it sorted.
Please tell me that isn't a compression fitting connector on a brake line that I see in that pic.
If so, I strongly recommend that you remove it, double-flare both lines and replace the connector with an inverted flare version. Compression fittings are not built or rated for much pressure.
  #17 (permalink)
Old 11-15-2011, 07:39 PM
That isn't a compression fitting on a brake line...
That is the cooling line for the Doug Nash 4+3 transmission that the Super T-10 replaced...I put a 180 block-off on the line going to and from the radiator just in case I ever want to put a DNE 4+3 back in it...
  #18 (permalink)
Old 11-15-2011, 07:44 PM
66GMC's Avatar
Good to know.
Thanks for explaining / reassuring.
rebuilt 700r4 wont shift spuradik Transmission - Rearend 2 11-01-2011 03:47 PM
79 chevy manual transmission dont want to shift fatboytruck Transmission - Rearend 8 03-26-2011 04:18 PM
1995 Impala Rebuilt Transmission Shift & Noise Problem Mobbvalous Transmission - Rearend 2 12-31-2008 03:50 PM
Transmission won't shift into 3rd gear. Why????? CCR Transmission - Rearend 7 02-03-2005 06:39 PM
th350 1st gear manual shift problem desman Transmission - Rearend 6 02-08-2004 03:15 PM
