Rebuilt Manual Transmission Won't Shift Into Any Gear? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2011, 05:53 AM
Hello!
I'm swapping a Borg Warner Super T-10 trans into my 86 Corvette, to replace the Doug Nash 4+3 trans. (The swap uses a special adapter to mount the transmission to the Corvette torque beam.) Trans is already in and new driveshaft is installed.
An Ohio rebuilder did the rebuild. The trans shifted into all 4 + R gears on the bench, using a 6" Crescent wrench to shift it. Now, when it is in the car and I am trying to select neutral for all gears, I can't get it to shift into any gear, nor reverse either.
No fluid in trans yet; driveshaft turns freely (wheels are off the ground). This would seem to indicate that I am in neutral.
I've read elsewhere that new synchro rings will make a trans shift stiffly for a while.
I'm ready to adjust the shift rods, but before I put the exhaust & X-braces on I'd like to make sure I didn't accidentally nudge two gears together...
What's a safe way to make sure I don't have a gear selection problem???
Thanks for your help!
Old 11-13-2011, 03:20 PM
Update: A member on another forum asked whether I was using my hand to push the gear links; I said yes; he suggested putting a visegrip on the link instead. With the visegrip the reverse link snicked right in; I can't get to the other links with the visegrips...
I went ahead and filled the gearbox with 90w gear oil; fitted & adjusted the shift rods; turned the driveshaft a couple times...I'll try taking the alignment pin out and shifting it with the Hurst shifter; maybe it'll free up...
Old 11-13-2011, 09:54 PM
Transmission Rearend
This may sound a little farfetched but I had a similar proplem after installing a GM T5 into my Flathead powered '52 F1. After wrestling the trans into place, finished hooking up starter, etc and installing the driveshaft, I realized I could not shift the transmission no matter what I tried. The next day and out of desperation, I took a pry bar and pried the driveshaft yoke rearward about a half inch or so and Presto! Problem resolved! I know this seems a bit simplistic but it may be all you need to do. I hope so 'cause I know how frustrated was.
Good luck
Old 11-14-2011, 07:35 AM
I'd like a little clarification.
What shifter are you using? and more importantly, from your 1st post, it sounds like the unit shifts without the shifter, and when you install said shifter, shifting becomes practically impossible?
Old 11-14-2011, 05:44 PM
No. There is no shifter connected to the transmission. I shifted it by hand on the bench using a 6" Crescent wrench. Now it is in the car and the links are bolted to the fork shafts. I am trying to push the links to shift gears. The trans is bolted to the engine; clutch installed; throwout bearing slips freely on the trans snout. Driveshaft turns freely. I can now shift in & out of reverse with a visegrip. I can't get the visegrip up to the 1-2 & 3-4 links to try it on them.
Old 11-14-2011, 07:05 PM
Wiki Edits: 27
input jammed ?
Do you have the right pilot bearing in the crank and is it pressed in the right distance. You might be binding on the input shaft end of the trans.
Old 11-14-2011, 07:23 PM
I believe so. It is a 'clutch kit' by LuK, the original equipment mfg'er...Pressure plate, friction plate, throwout bearing, pilot bushing, and butt plug...Bushing is pushed in all the way. Trans went in with no problems; no hangups, no binding...
I'll hook up the shifter on Thurs and see if that works.
I guess my question was if the synchro rings would 'stick' when new...It's been 35 years since I rebuilt a manual trans...I can't recall if they 'stick' or not...
Old 11-14-2011, 07:45 PM
Is there clearance between the shifter links and the side cover???...ie, did the shifter link bottom out on the side cover locking the link in place.
And what is a butt plug?
Old 11-14-2011, 09:03 PM
Last journal entry: It Will Work
Do you have any pictures? It sounds like the linkage. The linkage can be off just a little bit and you will have trouble shifting. The transmission has to be in nuetral before you adjust the linkage. Some of the leavers might say out on them,they face away from the transmission. Unhook the shift rods from the bottom of the shifter and see if you can move them by hand.
Old 11-14-2011, 10:07 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
Does this exploded view help?
The Richmond Super T-10 is a four speed countershaft helical
gear transmission synchronized in all forward gears. First and
reverse are constant mesh to prevent gear clash. Strut-type
synchronizers are provided for longer life and easier shifting.
#47's are the "Detent Kit" (1-2,3-4, and R)
If I understand the operation (and I think I do) if the front two levers are in the center detented position, the trans will be in neutral. Correct? I'm not entirely sure about the position of the reverse lever .... straight down would be the disengaged position?
I would think that it would be safe to assume that all 3 levers should be pointing straight down in order to be in neutral.
Old 11-14-2011, 10:10 PM
66GMC's Avatar
Please, for the love of God, man ... don't Google that.
Old 11-15-2011, 04:42 AM
There is clearance; I can wiggle the links back & forth by hand, they just don't go far enough to engage the gear...It might just be that I can't get a good grip on them to move them...I can't get back to the car until Thurs; I'll try connecting the linkage [shifter rods] and try it then...
Short splined plastic plug you use to hold up the friction plate while bolting the pressure plate on...It engages the pilot bushing & friction plate, has a loop on the end...Looks like a sawed-off input shaft...
Thanks for the replies!
Still wondering about the synchro rings sticking...
Old 11-15-2011, 05:44 AM
gmc1990rodder's Avatar
BUTT PLUG ?? WOW!! Here in florida we call it a clutch alinment tool... buuut I like butt plug better
Old 11-15-2011, 07:08 AM
Sometimes a ring can get forced on the cone or jostled and 'stick' but that doesn't seem like your problem. This takes quite a jolt and usually happens during shipping. Most people's new car transmissions (back until probably the late 80s) had this and they never knew, however applying engine torque pops the ring off and all is good. However this is one gear and it will lock the transmission up (when trying to turn it by hand). My inclination would be something in the sidecover or pilot. Pics would help.
Old 11-15-2011, 05:51 PM
My employer let me go after only 8 hours of work today, instead of the usual 10 - 12...So I got the shifter rods attached & adjusted...
Lowered the car, removed the shifter neutral adjusting rod, and tried the shifts...No go...
I was a bit irked...I got in the car and pushed the [hydraulic] clutch in to the firewall...and tried shifting again...
Eureka!!! It shifts!!! All 4 gears plus reverse engage now!!!
I have no idea why engaging the clutch should free up the gears...but it does...
My heartfelt "Thank You!" to all who responded to my panicstricken pleas here!!! Even if the ideas presented weren't the answer, they did prompt me to consider other alternatives that I might not have thought of...
BTW, here's a pic of the trans installed...
rebuilt 700r4 wont shift spuradik Transmission - Rearend 2 11-01-2011 03:47 PM
79 chevy manual transmission dont want to shift fatboytruck Transmission - Rearend 8 03-26-2011 04:18 PM
1995 Impala Rebuilt Transmission Shift & Noise Problem Mobbvalous Transmission - Rearend 2 12-31-2008 03:50 PM
Transmission won't shift into 3rd gear. Why????? CCR Transmission - Rearend 7 02-03-2005 06:39 PM
th350 1st gear manual shift problem desman Transmission - Rearend 6 02-08-2004 03:15 PM
