Rebuilt small block no spark - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2011, 11:45 AM
I just rebuilt my motor and when we went to atarr it it has no spark everything plugged in new control module no help even a hot wire from the battery to the distributer no spark! Any ideas ?
Old 04-10-2011, 12:01 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Assuming that we are talking about a stock GM HEI here ...
I suspect that you may have done the same thing I did ... washed it out in varsol and blew it dry.
It went from being a slightly grungy working unit to a squeeky clean paperweight. (D-Oh!)
The important thing ... if that new engine doesn't fire right up, stop cranking it, and buy a replacement distributor.
Old 04-10-2011, 03:13 PM
Countilaw's Avatar
Cox Custom Cars
Check an make sure you put the rotor inside the distributor. Next replace the coil.
Old 04-10-2011, 04:44 PM
techinspector1's Avatar
Wiki Edits: 326
Re-connect or replace all ground wires.
Old 04-10-2011, 05:52 PM
junior stocker's Avatar
Just went through something similar on my nephews 51 Bus Coupe with SBC/auto combo that I gave him. Completely new powertrain, and we just finished a rewire of the entire car. It ran fine before, and even during the rewire; after we finished, it would'nt start. We tried everything, checked and rechecked everything. Even swapped in a NEW HEI distributor. Finally, we replaced the brand new spark plugs with another NEW set; it fired right off. I've NEVER had anything like this happen before, and still don't quite believe it. I've never been so frustrated.
Old 04-10-2011, 05:56 PM
I guess you've got a pretty new paint job on the block. check the distributor and make sure it's grounded to the block, you might have to scrape some paint away.
no spark after rebuilt tbi 89chevy 1500 project Hotrodding Basics 7 09-09-2010 10:37 AM
Rebuilt small block Chevy using oil 40forddgc Engine 2 05-03-2010 10:09 AM
rebuilt chevy 327 small block wont fire 78 Nova Engine 3 01-12-2006 05:54 AM
rebuilt block? nova33 Engine 2 08-24-2003 07:06 PM
are 1 5/8 long tubes too small for a 414 ci small block? tony350ss Engine 8 03-17-2003 11:45 AM
