rebuilt th 400, problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2007, 01:05 PM
i just got my th 400 rebilt by a shop, and my old th400 had a manual vavle body in it,, so i told them to put it in the rebuilt one,, well i put the trans back in the car and put it in first and it ant going in first,,, it did a couple of times but not all the time,, so what could it be,, are there any balls to remove when installing a manuel valve body, the chevelle will shift into 3rd no problems,, car does drive down the road , just not in first,.
Old 11-10-2007, 08:30 PM
jakeshoe's Avatar
Reverse manual VB or forward pattern?
Old 11-11-2007, 02:49 PM
it shifts foward to third,, so i assume foward..
Old 11-11-2007, 03:58 PM
jakeshoe's Avatar
OK,
Lots of questions still.
First,
By no first gear do you not have engine braking in 1st or does it always take off in 2nd, even with the lever in the 1st position?
Are you sure the shift linkage is properly adjusted? Simple stuff first...
Does this unit retain the vacuum modulator and vacuum connection or does it use a plug in the vacuum mod place?
Old 11-11-2007, 05:37 PM
no plug on moderator,, not hooked up, manual valve body,, i dont need it right,, yes adjusted cable , check fluid,, etc... i put it in 1st manualy and it starts in secound,, but today i test drove it around and it seems fine now.. so i will continue to test it and play on it hard... is there a break in procedure
400 cid SBC Shades_o_Grey Engine 20 02-04-2008 01:28 PM
Powerglide trans to 400 Chevy motor K9sicem Transmission - Rearend 3 07-09-2006 09:43 AM
Various carb problems BuickLeSabre1960 Engine 3 10-27-2004 05:46 PM
which one to turbocharge 355 or 400 TerroRx7 Engine 11 10-13-2004 06:45 PM
460 flywheel, 400 pressure plate? billybob_v10 Transmission - Rearend 2 07-02-2004 12:51 PM
