rebulding a c6 transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2006, 02:26 PM
does anyine know where I can find some good instructions for rebuilding a
ford c6 transmission? I have never rebuilt one and I now have two that need some work.
Old 07-06-2006, 04:43 PM
scrot's Avatar
Try this repair manuals
You can buy the ATSG repair manual for about $25.
Old 07-06-2006, 05:31 PM
rebuilding c6
thanks for the info. I did not know where to look online.
Old 07-06-2006, 05:44 PM
Jmark's Avatar
sixteen bucks in ebay including shipping
Old 07-07-2006, 06:52 AM
rebuilding C-6
If you need parts try www.bulkpart.com also I have a rebuild kit, clutches, steels.transgo shift kit. thrust washers, torrington bearings, sprag, band, modulator, etc all new for sale. $ 150.00
Old 07-07-2006, 07:31 AM
cboy's Avatar
Last journal entry: Finished
At hammerfrick's link for parts there is a notation for some of the rebuild kits "thick fwd friction" and "thin fwd friction". Am I correct that these ONLY refer to a rebuild kit for a 4 wheel drive vehicle? And how does one know if they need the thick vs. the thin?
Always learning...and sharing what I've learned.
Old 07-07-2006, 01:20 PM
Thin VS thick
The thin clutches are for the earily C-6, The thick (.075) are for the 76 and later trannys.
Ford "Y" Block and a later C4 or C6 Transmission RAW Transmission - Rearend 6 04-02-2006 09:01 PM
C6 transmission cooler lines question? Steve-0321 Transmission - Rearend 4 02-04-2006 01:04 PM
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 04:15 PM
fluid capacity of a ford C6 Transmission Dubz Transmission - Rearend 4 12-13-2003 12:10 PM
Power Loss for c6 Transmission Dubz Transmission - Rearend 3 07-16-2003 08:55 AM
