recalibrating kickdown point on a TH 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2007, 04:06 PM
dawg's Avatar
NAVY VETERAN
since ive changed my rear from 3:08 to 3:73 the kickdown has been acting funny.
Itll kickdown for 2 to 3 seconds then back?
with the 3:08 it would hold it until I let off the gas.
Im assuming that the modulator would need an adjustment.
also id like to move the downshift up some
example : it would not go into kickdown over 55 mph
anything under 55 it would kick down
id like to move the limit up to 65 if possible
maybe a govenor spring or weight adjustment?
Old 05-04-2007, 07:18 AM
dawg's Avatar
NAVY VETERAN
anyone?
got any idea or a fix
Old 05-04-2007, 06:51 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
you are incorrect on the modulator comment / adjustment
such an extreme change in gear ratio has created this.
gov weights would help
a Stiffer spring on the detent regulator valve would help.. TransGo has a spring in their kits. 350-1&2
Cam/Lifter Question about Ramjet 350 Jake Harsha Engine 20 07-07-2010 06:22 AM
Bog/Black Smoke on Olds 350 at 3000 rpm JohnTN Engine 4 03-17-2009 11:39 AM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 09:43 AM
possible 350 block purchase - comments please idrva55 Engine 17 12-09-2007 09:29 PM
350 kickdown adjustment? 54 Chevy Transmission - Rearend 2 09-08-2003 06:54 PM
