recamming the sbc 406 questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2010, 06:22 AM
dawg's Avatar
NAVY VETERAN
going with an isky hydraulic roller
cam card here.
anyone use this cam ?
i got 3:93 rear ratio and 2500 stall converter on a built th350.
brodix -10 aluminum heads
11:1 compression
also I got 150 nitrous shot on the plate.
will this cam work ????
thoughts???
TIMING CHART
[COLOR=#ff0900]PART NUMBER: [/COLOR][COLOR=#ff0900]211282/294[/COLOR]GRIND NUMBER: rr-282/294ENGINE INFO: CHEVY SMALL BLOCK V8 305-350 CU.IN. 1988-UPAPPLICATION: SPECIAL REMARKS: HYDRAULIC ROLLERPRODUCT USE: STREET/STRIPRPM RANGE: 3000-7000Valve lift is calculated with zero lash and rocker ratio of 1.5INTAKE TIMING DURATION: 282deg.OPEN: 31BEFORE TDCCLOSE: 71AFTER BDCCAM LIFT: .353"VALVE LIFT: .530"VALVE LASH: .HOT.COLDEXHAUST TIMING DURATION: 294deg.OPEN: 77BEFORE BDCCLOSE: 37AFTER TDCCAM LIFT: .367"VALVE LIFT: .550"VALVE LASH: .HOT.COLD
LOBE CENTER: 110 deg.OVERLAP: 68 deg.CAM ADVANCE: 0 deg.THE ABOVE TIMING IS CHECKED AT .020(OPEN) LIFTER RISE.020(CLOSE)The following timing is taken at .050" lifter rise and gives a more accurate determination of camshaft position.INTAKE DURATION: 234deg.OPEN: 7BEFORE TDCCLOSE: 47AFTER BDCEXHAUST DURATION: 246deg.OPEN: 53BEFORE BDCCLOSE: 13AFTER TDC[COLOR=#ff0900]RECOMMENDED ISKY CAM KIT PARTS AND SETUP INFORMATION
[/COLOR]LIFTERS: USE STOCKLIFTER TYPE: HYDRAULIC ROLLERSPRING: 6105TYPE: dual W/DAMPERDIA.: 1.430"RATE: 330 lbs per inchINSTALLED HEIGHT: 1.812"SEAT PRESSURE: 135 lbsOPEN PRESSURE: 315 lbsCOIL BIND: 1.120"SPRING SHIMS: # 2STEEL RETAINERS: 507-STATITANIUM RETAINERS: 60-TIPUSHRODS: 203-HG-.460"TYPE: heat treated non-adjLENGTH: 7.200"DIA.: 5/16"ROCKER ARMS: 204TYPE: rollerRATIO: 1.5VALVE LOCKS: VL-32VALVE LOCKS: VL-32REV KIT:
[COLOR=#35415b]home | what's new | tech info | news | catalog | apparel | about | contact
[COLOR=#c5cbd9] 2002 Isky Racing Cams. All rights reserved. [/COLOR][/COLOR]
Old 07-25-2010, 03:45 PM
techinspector1's Avatar
Wiki Edits: 326
Just a couple of thoughts.
1. You may need a little more converter.
2. If you plan to use the full range of the cam up to 7000, you will need a rev kit in the lifter valley. Juice rollers are heavy and will tend to leave the lobe profile at 6200-6400, depending on whose lifter you're using.
Old 07-25-2010, 03:50 PM
Sounds good but as mentioned might could use a little more converter an might even think of a little more gear. Depends on tires. Make sure you have some decent fuel flow.
Old 07-25-2010, 06:30 PM
dawg's Avatar
NAVY VETERAN
I got a 3000 stall converter with anti ballooning plate just incase.
ill wait on the gearing because im told the 406 will pull those gears without a problem but ill see i guess.
Old 07-26-2010, 06:53 AM
dawg's Avatar
NAVY VETERAN
going with the whole matched isky kit.
Cam Kits Include
Cam
Hyd. Roller Lifters
Pushrods
Valve Springs
Spring Shims
Steel Retainers
Cam Sprocket Lock Plate
Thrust Bumpers
I already got a crane rev kit but thinking i might need to change due to the differences (from flat tappet to roller)
list your 400 or 406 sbc combo's here,,, what works the best for you tiresmoke55 Engine 16 08-12-2010 08:26 PM
Estimated horsepower for my 406 sbc drag S-10 Engine 8 11-15-2005 10:46 PM
from 2-horse B&S to sbc 406 sandlapper Introduce Yourself 2 10-28-2005 10:06 AM
Dumb Question about a SBC 406 Mustangsaly Engine 3 08-06-2005 09:01 PM
Sbc 406 sb72elcamino350 Engine 9 03-05-2004 11:59 AM
