Reccomendations on Which Torque Converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2012, 08:07 PM
Im building a 67 Chevelle, im putting a 427 BB in, compression 10.5 - 1.. HP aiming for 450 - 500 ... Turbo 400 with a B-M stage two shift kit, 12bolt posi rearend 3.73 gears. I plan on making a street friendly - but enough power for beating up on my buddies on weekends type of Chevelle, I know what torque converters do, but how high stall would you reccomend? I dont realy want to spin/stall every time i take off driving... Thanks
Old 04-28-2012, 01:09 PM
Banned User
Well, the smart people(unlike myself) here probably need to know more about the cam and overall weight.
The dumb people (like myself) would wonder why can't a stock converter work with 3.73 gears?
Old 04-28-2012, 08:56 PM
pricesgarages's Avatar
a rough guess would be 500rpms above the the cams base power band examle 1500-6500 cam use a 2000 coverter any thing more than 2400 will slip under normal driving
Old 04-28-2012, 09:33 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Best answer is to call the torque converter manufacturer and give them your vehicle specs and get a recommendation. Don't buy an off the shelf converter, you never really know what you're getting
Old 04-29-2012, 10:46 AM
Banned User
So, why can't a stock converter work with 3.73 and lower gears if you have a hot engine?
NOTE: i know nothing about torque converters except what they do in a basic sense.
4l60e torque converter clutch torque capacity rx191 Transmission - Rearend 1 04-05-2011 04:03 AM
Torque Converter to Flexplate Torque Spec. Needed - 2004R Zeeb Transmission - Rearend 1 05-26-2010 06:47 AM
Bellhousing bolts and torque converter bolts torque specs Davey3ch Transmission - Rearend 2 09-04-2009 11:05 AM
B&M Torkmaster 2400 rpm stall converter vs. stock torque converter??? zbhover Transmission - Rearend 2 11-02-2008 07:52 PM
torque converter 85 regal Transmission - Rearend 3 03-23-2003 03:22 PM
