Recharging A/C - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2006, 06:19 PM
MI2600's Avatar
Member# 3287
Recharging A/C
I have a complete a/c system on the '86 El Camino, the old R12 model. It didn't work when I bought the car, but I decided this year I would make a stab at fixing it. I replaced the o-rings and had the system vacuumed out by a friend. I bought an R134 conversion kit.
Yesterday, I put the kit oil and three cans of R134 in the system. The kit said put in 80% of the recommended R12 capacity which was 3.25 lbs. The last can of R134 emptied in a heartbeat. I now get cold air, but I have a slight "growl" when I let off the gas. I assumed it was the compressor since it's the only moving part. But, a friend said I might not have enough refrigerant in it. It doesn't have the bubble sight gizmo that the older models had.
How do you know when the system is full?
Old 07-02-2006, 06:53 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
You need a set of A/C gauges or you need to install the set amount of freon into the system. I would also look at adding some more A/C oil. If this does not stop, let me know I have a product from BG thats called compressor quiet. works very well.
Steve
Old 07-02-2006, 09:28 PM
WakBordr7387's Avatar
Gone fishin'
Last wiki edit: Removing stuck fasteners
Last journal entry: blah.......again
Wiki Edits: 2
How much does that compressor quiet cost? Ive never heard of anything like that, but Ive got the same problem with my car right now after charging the A/C.
Brad
Old 07-02-2006, 09:48 PM
MI2600's Avatar
Member# 3287
Steve,
The kit came with a small (maybe 6 oz) can of some kind of "retrofit oil" that went in first.
Couple of questions:
Do you think I should try to put another can in...if I can find it?
Is there a suitable substitute if I can't find it?
Is it possible to overcharge the system with those 1 lb cans?
OK, I know, that's three.
Old 07-02-2006, 11:52 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
I would add some more refrigerant. r134a isn't as picky if you over charge it like r12 is. you could take it back to your friend and let him suck it down again and hell be able to meter how much more goes in. He should only charge you for the refrigerant he adds on top of yours.
To leave or keep A/C chevyguy General Rodding Tech 13 08-14-2010 04:06 PM
A/C on = Overheat? Fragzem Engine 7 08-20-2005 12:45 PM
1951 Buick Roadmaster a/c system madgift Interior 3 08-13-2004 07:49 PM
82 Chevy 4x4. A/C, header bracket TJW Engine 2 10-27-2003 06:51 PM
A/C question Paco Engine 1 06-03-2002 07:01 PM
