Well dunno what they say now but the old time recope for those was to use a 327 365HP cam and about a 500 CFM 4bbl and what we used to call fuelie heads which are the 2.02 intakes..That combo was hard to beat back in the day..
OMT
283's are hard to make a lot of power out of due to the small bore, a 327 foundation would be a lot better. With that being said we had a 283 on the dyno a month or so ago with 2.02 double hump heads, 9.5:1 compression, 230 duration cam, around .500 lift, high rise Holley dual plane and a 570 Avenger. It made 230 HP. They make nice drivers and can be peppy.
A couple of months ago we had a 408 on the dyno with ported double humps. 240 duration, .600 lift, 10:1 compression, Performer RPM camshaft, Holley DP 750 and it made around 440 HP. It also had a couple inches more vacuum as well. This motor sounds narly and pulls very hard. Cubic inches simply make it easier to make more power throughout the RPM curve in a naturally aspirated application. That is why, as well as the base level 4" bore, the bigger motors are so popular. |
Back in high school a friend of mine had a 69 Nova with a 283, holley 600, dual plane, headers, unknown solid cam, muncie 4 speed, 3.73 posi. The car was a hell of a lot of fun. 400 and 455 Transams and 5.0 Mustangs were stomped regularly.
Have your rotating assembly balanced. Get your compression ratio to match the cam you'll be using. Use ARP rod bolts. |
call a freind of mine..James Lee . in broken arrow.Oklahoma...James lee automotive...he runs a 55 chevy..super stock...with a 256 ci motor and is the current national record holder..with a 11.?? e.t...he is a wizz at those small motors..and is super frindly to talk to too...
| 283 Harmonic Balancer | JamesD | Engine | 29 | 03-14-2007 05:36 PM |
| 283 stroker (307 cid) question | Viking427 | Engine | 4 | 04-04-2005 10:40 PM |
| 283 piston alternitave | jeff of nc | Engine | 3 | 10-10-2003 04:33 PM |
| high performance 283 | steve | Engine | 2 | 06-22-2003 03:25 PM |
| 66 283 auto / 67 283 swap Question | FasterPastor | Engine | 1 | 11-05-2002 12:48 PM |
