Reclaiming old brake fluid? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2005, 06:43 AM
Has anyone out there successfully reclaimed DOT 3 or 4 brake fluid? I haven't been able to find any recycling/hazardous waste organization here in Vermont to accept it and my buddy who burns waste oil to heat his shop won't take it either.
I've read that some people get rid of the water by boiling it, then filter and reuse it. Has anyone tried it? Seems like if the temperature were watched till the original boiling point spec were reached, it'd be good enough to reuse. Any other methods? Vacuum?
Between what I've bled out of systems and containers that were open too long, I've got somewhere around a gallon of the stuff. The idea of not paying to buy new, not paying to get rid of, and having a lifetime supply of the stuff on hand is appealing.
Neil
Old 11-08-2005, 10:36 AM
59 f100's Avatar
rubber on the road
well at the shope that i work at we burnd it in the wast oil furnace but if you find a way to reuse it email me because we go through alot bleeding brakes you know that vermont rust gets everyware sbreznick@burrburton.org
Old 11-08-2005, 04:59 PM
abstruse dutch uncle
Water is not the only problem with old brake fluid. It loses its corrosion inhibitors, even if the water content is minimal. Only a Ph test will tell you if this has happened.
http://www.babcox.com/editorial/bf/bf50412.htm
As far as disposal, it is considered a hazardous waste. It's poisonous in all forms and breathing in the burning fumes can make you seriously ill.
Recycling may vary depending on location. You might have something in your blue pages for waste disposal under a local gov. listing.
Old 11-08-2005, 05:06 PM
steve t's Avatar
ex biker, now hotrodder
it aint worth the hassle to reuse, it dont cost much for new, i wish we could reuse gas, ha ha
Old 11-08-2005, 06:42 PM
Out in CA they have a Household Hazardous Waste collection once a year or so. I keep all my non-oil fluids and turn them in there.
Old 11-09-2005, 09:34 AM
Thanks for the good link, yesgo...Of course, it being an editorial, it's an overview, lacks detail and raises more questions than it answers. That copper contamination is a problem is something I didn't know- guess I'll have to start using stainless brake lines instead of copper. Corrosion bites, don't it?
Flushing the old brake fluid out with new seems like good practice, but how much of the fluid does bleeding actually remove? For instance, the brake lines on my Nova enter the rear cylinders near the top, next to the bleeders. Seems to me that during bleeding the fluid would flow from the line to the bleeder, leaving most of the old fluid still in the cylinder. Same configuration as the front calipers, which, according to the editorial, are the lowest point in the system and subject to the most corrosion. The lines and master cylinder reservoir would be flushed, at least, but there would still be a lot of old fluid left in the calipers and cylinders. I 'spose they could be taken off and turned upside down every time the system is flushed, but doing that every few years seems like work.
Anyway, back to the original subject. Boiling will get the water out of old fluid, we know that. Maybe corrosion inhibitors (what are they, anyway?) can be added back to the fluid, or maybe an anode could be put in the master cylinder reservoir. (A new product? If you see an ad on late nite TV for brake fluid additive, you'll know I've gotten a real job.)
But, I digress. Time to fix more rusty brakes.
Old 11-12-2005, 08:53 AM
56 Project's Avatar
Last journal entry: I've Changed My Project
Copper is not allowable for brake lines. So how does the copper get in there?
Old 11-12-2005, 08:40 PM
It is part of the alloy on the interior of the steel tube, to resist rust.
brake fluid rally4x4racer Hotrodders' Lounge 1 12-15-2004 05:54 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 07:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 04:34 PM
Regretting using silicone fluid - advice? Limey Simon Suspension - Brakes - Steering 3 04-30-2003 07:07 AM
Dot 5 Silicone Brake Fluid?? Yes or No ?? Jim Weeks Suspension - Brakes - Steering 18 04-15-2002 07:22 AM
