Reclearing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2004, 01:12 PM
daimon1054's Avatar
Reclearing?
My truck has a few chips, it is my daily driver and has been neglected some. What I want to do is scuff the whole thing, touch up the chips then lay on 2 more coats of clear. Right now you can feel the little pocks in the clear from time and lack of wax so I know the clear has to be getting thin, I just want to get it back in shape before I have to spend big bucks to repaint it.
Will this work?
Old 03-05-2004, 09:31 PM
fisher57's Avatar
daimon hello youve got the right idea but i would wet sand the whole hood w/some 500 grit , featherout any pock marks and try not to cut through the original color (base) and then make sure its good and dry mask it off and lay out your new base color and blend it back into the hood a little ways and then apply your clear and you should be in good shape . this should not use up much material so it wont cost you a ton of money . and it will save ya much more money than if youd let it go good luck . fisher57
