recoat acrylic enamal - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2004, 05:47 AM
I got one coat of acrylic enamal(Napa) sprayed on my firewall last weekend before I had to leave. Do I need to scuff before recoating this weekend??
Old 11-05-2004, 09:04 AM
If you only have one coat you can have a problem. You will need to LIGHTLY scuff it, I mean LIGHTLY. Use a gray scuff pad and lightly scuff it so you don't go thru. With only one coat, there could be a real issue with lifting, the solvents from the next coat can get under that coat and cause it to lift.
Be sure it is warm enough and you have the proper temp reducer so it isn't too "wet".
