Recomendations On Buying A New 4 Speed Transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2006, 12:34 PM
Hi guys I am at the point in the restoration of my 69 Camaro that I want to but a 4 speed. I don't want a 5 speed. What are your recommendations I have a chevy small block with about 410 hp street driven only, 3.73 gears. I have heard a lot about these new M22 super case transmissions are they all that are they as strong and dependable as everyone says? How loud is loud? that's a big concern. Can you talk to someone in the car? I think having it for resale value is good.
I have a buddy who will sell me his M20 for $500.00 but it needs a complete rebuild. What are your thoughts. I don't no if it needs a rebuild kit or gears, etc. So that could be pricey also.
If I go with the new M22 who do you recommend?
Any and all information you can give me would be great.
D
Old 02-08-2006, 01:00 PM
302 Z28's Avatar
The M22 can certainly handle the HP you are talking about with no problem whatsoever. You are wise to be wary of the used M20. You very well could spend a sizable chunk of change on it. On the other hand, if you have the chance to do a visual internal inspection look for any gear teeth missing. Also look at the synchro ring engagement cogs on the gears. If they are all rounded off I would pass on the trans. If it appears to be in pretty good shape it would be a fairly good buy and could be freshened up with a master rebuild kit for about $160.
For a new M22 see the below web sites.
www.4speed.com
www.gearzone.net
They are both reputable firms.
Vince
Old 02-08-2006, 11:54 PM
I'd be a little leery of the close-ratio trans with 3.73 gears. Final drive ratio in low is 8.2:1, which would tend to be a little sluggish from a dead stop. I'd go with the M20 or M21W.
Old 02-09-2006, 08:15 AM
fat40's Avatar
Recomendations on buying a new 4 speet trans
I run a M 20 in my 40 ford ,also I run 3:55 Ford 9 inch posi , and a 383 stroker with 500 Hp and it works great, like you say the rock crusher is real noisy , I myself would recommend the M20 or 21 .I just had my M20 refreshed for $ 150.00 .
Fat40
Hotrodders Knowledge Base: Transmission - Rearend Jon Transmission - Rearend 0 11-26-2005 06:23 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
Transmission swap information jwhclayton Transmission - Rearend 5 06-23-2004 02:12 PM
M-22 Transmission in a toyota?? traub83 Transmission - Rearend 0 05-27-2004 08:10 PM
54 223 Ford 3 speed manual transmission Neal0o Transmission - Rearend 0 09-17-2003 11:55 AM
