Recommend Intake Manifold Gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2012, 04:46 AM
I have a 327 with 205 cc aluminum heads bolted to an LT1/Z28 intake manifold which has been ported. I'm not sure of the port sizes. The head ports are slightly larger than the manifold ports. Fel Pro 1205 are OK once I trim them to size. 1206's require less trimming, but are too large and leave about 1/16 sealing surfaces around much of the intake manifold ports. I'd go back with the 1205's, but noticed that they had crept in the areas of both water crossover ports. I had installed them with RTV on both sides of the gaskets on the water ports. I'm looking for a better, stiffer gasket that won't walk around as much as the FelPro 1205's. Thanks.
Old 06-19-2012, 06:37 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Generally speaking, using RTV acts as a lubricant until it's set up; using it alone can let the gaskets slip out of position when tightened. Instead use weatherstripping cement or Gasgacinch to hold the gaskets in place on one side, nothing on the other side.
A light application of RTV (following the directions for skim time) around the water crossovers can be used in conjunction with the cement.
Old 06-19-2012, 09:10 AM
Banned
Since you're not happy with any gasket you can get material to cut your own- some companies will also cut one for you to your specs. Cobalts method for gaskets will work, if you have patience I coat one side with rtv, place the gasket, smooth it out and use little claps to hold it (if bolts aren't adequate). You then wait for it to cure before placing the otherside (over night). I've never had problems with this method but it takes time.
My pop uses contact cement, which cures really fast and holds rock hard, but god help you if you need to remove it. He gets some industrial stuff from Grainger and it gets hard as nails.
Old 06-19-2012, 03:27 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
4
Actually that's what Edelbrock recommends as well. Of course they want you to but their Edelbrock branded weatherstrip cement. I've uses 3-M cement for as long as I can remember. Black or yellow, doesn't matter.
Old 06-19-2012, 09:11 PM
Banned
Originally Posted by cobalt327
4Actually that's what Edelbrock recommends as well. Of course they want you to but their Edelbrock branded weatherstrip cement. I've uses 3-M cement for as long as I can remember. Black or yellow, doesn't matter.
How long is cure time? The rtv I use is hours, the contact cement my dad uses is a couple minutes, we've used that cement for everything from gaskets to headliners and seat covers but that **** gets rock hard and one you touch the two coated pieces together you cannot adjust them so you better make sure your alingment is perfect, rtv is more forgiving but takes much longer to cure.
Old 06-20-2012, 01:39 PM
MRTS33's Avatar
33 Pontiac 3W Sport Coupe
I do a bit of boating. Evanrude makes a gasket cement/softner that is the really good. Comes in a small can with a brush and is brown. The old guy at the marina would use an old catalog. Open it up lay the gasket on it and paint both sides. Place the gasket put the intake on just snugged up not torqued to spec yet let set for like 1/2 an hour then tourque. Good to go. Always stayed soft to.
Old 06-20-2012, 06:39 PM
Agreed, RTV is the culprit, not the solution.
We use Permatex "Aviation". It's a brown alcohol-based "goo" that dries once exposed to air. It comes in a little bottle with a brush. It's FAA approved for internal combustion engines, so it can't be "bad". The "Gaskacinch" is a similar sealant. "Indian Head" and Permatex "300" are two more that are similar and work in the same manner.
We use the same method as cobalt327. "Paint" one side around the water ports (head side) and leave the manifold side clean and dry.
For a mass-produced component, it's pretty hard to argue with Felpro Performance's line of gaskets. Their intake sets are as good as any out there anywhere near the price (IMO).
Jim
Old 06-20-2012, 09:09 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It's able to hold a gasket in position almost immediately if applied by the directions. I wouldn't call it "rock hard". You can see the info sheet for a description. The type I use comes in a bigger tube, basically the same thing I believe.
A couple cut off bolts or studs can be used to position the gasket perfectly, remove before installing the intake.
Intake manifold gasket LordTTK Engine 2 03-28-2011 05:38 PM
intake manifold gasket? hemi joe Engine 4 04-23-2010 04:14 PM
which intake manifold gasket? leastbay Engine 22 11-09-2006 04:36 PM
Which Intake Manifold Gasket? oregon chevelle Engine 10 04-18-2006 12:11 AM
351w intake manifold gasket 72Bronco351 Engine 3 11-25-2003 03:18 PM
