Recommend me a build! 400 sbc, 64cc heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2007, 10:07 PM
So, this is my first sbc build - and I need some help! I've got a '70s 400 sbc 2 bolt short block, and a set of bare Trick Flow aluminum heads with the following specs...
Originally Posted by Trick Flow
Chris,
You just bought yourself a set of 64CC combustion chambered, 192 CC intake port, 2.02/1.60 valve High Port heads. The springs that we put in them are good up to .600 valve lift. If you need more information let me know.
Gregg Changet
Trick Flow Specialties
Technical Advisor
E-mail: gchanget@trickflow.com
Ph# 330-630-1555 ext. 6738
Fax# 330-630-5565
Where can I go from here with another $800 - $1,500? What CR? What pistons? Rockers? Cam? Carb? Intake? I need it to run on CA 91 pump gas, and I'm not really interested in nitrous. I'm looking for a very streetable engine, possible daily driver duty and 1/8 and 1/4 mile fun once a week. This is a budget build - I'm not afraid of wrenching myself or used parts so assume the only thing I'm going to farm out or pay top dollar for is the machining. (Can anyone recommend a good machine shop in the Los Angeles area?)
I have a '63 C-20 I can drop this into but if this turns out to be a sweet little motor I'll stick a Goodwrench 350 I have hanging around in the truck and find a nice little 2 door for this 400.
Old 03-16-2007, 11:29 PM
You should try this
400ci 10.25:1cr
hyperutectic pistons,with moly rings
6" I-beam rods with arp rod bolts
274H xe cam
gear drive or double roller timing chain
1.6 roller tip rockers
Performer rpm intake
670cfm street avenger holley
hei igntion 50k coil
keith black pistons(KB130)
http://shop.enginekits.com/osb/itemdetails.cfm?ID=795
I-beam 6" con. rods
http://shop.enginekits.com/osb/itemdetails.cfm?ID=2251
Old 03-17-2007, 12:03 AM
327NUT's Avatar
Is Anaheim too far away for you??
Old 03-17-2007, 08:06 AM
No, Anaheim is pretty close - do you know a good shop in Anaheim?
Old 03-17-2007, 08:14 AM
King of my Man-cave.
Originally Posted by F-BIRD'88
Build for 91 octane reliably you want a true 9.5:1 or alittle less. Use GM 350 5.7" connecting rods. use ARP rod bolts. A few of the rod bolt heads will contact the cam lobes. You have to grind the rod bolt head edge to allow .030" clearance minimum on a few of the rod bolts when using GM 5.7" rods with a 400 crank. The machine shop can take are of this for you or you can do it yourself. Requires mocking up the block, crank, rods, pistons and camshaft. I usually borrow a big race roller cam (260+ dur@.050) to do the rod bolt clearancing so that any street sized cam that the motor will see in the future, will fit with out rod bolt head interferience.
Use Keith Black Hyper KB -168+.030 22cc D dished pistons. You must set the top ring end gap large. .032" is not too large for this type piston.
it is just right for this hyper piston and mild N20.
With a non decked 400 block and felpro .039" 400 gasket your cr will be 9..30:1... with a cleanup cut on the block (.005") your cr will be 9.4:1. I would not go higher.
The above mentioned Comp XE274H10 will work well with a Performer RPM manifold.
The heads must be drilled for the extra 400 steam holes.
The Stock GM 400 cast crank is plenty strong.
The bottom end assembley must be rebalanced.
Are your TFS heads the 23deg heads or the "Twisted Wedge Heads"?
I would be very careful with timing using that cam with this build. The Comp XE series is designed to build a cylinder pressure and Comp is revising their recommendations for them because of that (they work almost too well). Also, the KB pistons require less total timing (around 30 degrees). I would recommend a cam with a little more duration at .050" lift and decking the block to optimise quench. This build will probably end up costing more than you think (they always do).
tom
head ache. sbc heads excaliberprime Engine 7 03-07-2007 06:03 PM
getting old iron heads to flow? (SBC) KNanthrup Engine 9 12-21-2005 05:06 PM
sbc 350/400 heads help Jwhite Engine 6 09-04-2005 05:56 PM
sbc heads shieldbreaker Engine 5 08-27-2005 08:12 PM
sbc 400 build up rahn Engine 11 12-21-2002 07:25 PM
