Recommendations? Anyone? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2005, 06:46 PM
Huckster's Avatar
I'm lookin' to learn.
Last journal entry: Project has left the building...
So I've finally separated body from chassis on my 1934 Olds. I'm in the process of removing fittings, brackets, etc and digging dirt and debris from the frame rails. During my little chore I've discovered that the insides of the main rails where the engine compartment would be are badly rusted. The rust appears to penetrate about half the thickness of the rail in quite a few spots and flakes off in thick chunks. I won't know the full extent of things until I blast the frame but it looks quite bad.
I'm looking for options here.
I'm a newbie at all this so fabricating a new chassis is out of my league, and buying a new frame just isn't in the budget. Should I look at sliding a chassis from something else under my project or can I cut off the front part of the chassis and graft on something from a modern car like a Camaro. My brother-in-law is a welder so I have that covered (he's gonna teach me as we go along).
Any thoughts would be greatly appreciated.
Brent Huculak
1954 AD Lover
Old 05-16-2005, 07:06 PM
broncoII88's Avatar
Do the right thing...
Patch it if it don't work!
If the rust is as bad as you say it is, then you could cut out the rusted sections, and patch the frame with thicker pieces. But make sure your welds are good before you attempt this. Are you going to learn MIG or TIG?
Old 05-16-2005, 08:50 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Do a search on the knowledge base
And search the project journals...there has been a lot said about frame swaps..adding late model front ends and all that in earlier posts..
Take your time and do some research and I am sure you will come up with an answer..
Welcome aboard...
OMT
Old 05-17-2005, 10:24 AM
Wiki Edits: 49
After you blast, if the rust damage is all the way through simply cut out the damaged area and replace with new metal. If you're going to slip in a modern V8 I would also suggest boxing the frame from the front crossmember back to the trans mount crossmember. It will add stiffness and strength to the frame and in most cases it will make the installation of the new motor mounts easier.
Old 05-17-2005, 03:42 PM
Huckster's Avatar
Neat thing about this frame is that it is already "pre-boxed" from factory in the area your mentioned. The sections are riveted together so I would just weld it for added strength.
I'm not going to be able to get to blasting till next week as I work the next 5 days but I'll take a pic or two and try post them tonight if possible. The rust is inside the boxed area outside rail on the passenger side...not sure if it will be visible in the photos.
Brent
1954 AD Lover
Old 05-17-2005, 06:18 PM
Huckster's Avatar
Here's some pic's ...kinda hard to see the problem without blasting.
The yellow line is the interface between the 2 parts of the chassis rail and the white lines roughly show the boundary of the rusted section (half way thru the thickness or more). The section appears to be about 18-22 inches long. The problem is not evident on the driver's side so I think the car must have been sitting such that water pooled on the passenger's side for long periods of time (before it was dragged from the field).
Anyways have a look and let me know what some of you think.
Brent
ID:	5006   Click image for larger version
ID:	5007   Click image for larger version
1954 AD Lover
Old 05-17-2005, 06:27 PM
rust
i would put angle iron thru those factory cutout holes in frame and weld it in . not the best way but will do the job if on a budget or cut that section out and use angle iron for that (edge - corner )
Old 05-17-2005, 07:44 PM
30desoto's Avatar
Dodge ain't all bad
Huckster
With a frame in that good of shape (almost new by the pictures) I think you have a lot to work with if that is the only bad spot you have. That can easly be cut out and repaired with either angle steel or two pieces of flat steel. The question is are you going to want to replace the front suspension to something newer or just rebuild the old suspension, what type of rearend will you use new or old suspension in the rear. If you think that you might want to change the whole frame for one that is newer with better suspension, than to locate one that will come close measure you frame length and width, wheel center to wheel center, and start looking for a small truck frame that will come close to your size and start adapting, wheel center to wheel center is the most critical of measurements, frame width and length can be adjusted fairly easy, I would check for the size of a 1500 S10 two wheel drive it may be close. Everyone has alot of answers here on the board with alot of knowledge, I have all the confidence in the world that if I can learn here and do things (cause I'm stupid, dumb and incompetent) then I know that you can do what needs to be done.
by the way WELCOME
30dee
Old 05-17-2005, 07:53 PM
Wiki Edits: 49
Originally Posted by Huckster
Neat thing about this frame is that it is already "pre-boxed" from factory .......
Well DUH! I was thinking Ford for some reason. Guess I should engage brain before typing next time.
Old 05-17-2005, 09:27 PM
Huckster's Avatar
It's all OK Centerline. Everything out there from the 30's is pretty much ford so I can't fault you there.
And as for suspension 30D I dont think I'll rebuild the original since its bent, smashed, or missing. I was thinking 2nd gen camaro for the rear as the size and trackwidth are very close to the original (less the tunneled driveshaft). As for the front I am leaning toward IFS but grafting a 2nd gen camaro front clip/ subframe isn't out of the question either. I looked into S10/15 chassis for the car as well and the wheelbase of the truck is only 3-4 inches longer than the car- I just haven't found a trackwide measurement for comparison yet.
My head hurts....repair, swap, or graft new IFS and IRS onto old. Guess I got some thinking to do.
Thanks for input all, greatly appreciated.
1954 AD Lover
Old 05-17-2005, 10:31 PM
Wiki Edits: 49
If you're thinking of a front clip then I would suggest a Nova instead of a Camaro. The 30's cars are a bit narrower than the later cars and a Nova clip is a bit narrower than the Camaro but provides you with the same advantages. Measure your front track width to be sure.
Old 05-17-2005, 10:38 PM
poncho62's Avatar
Wiki Edits: 5
I would think that even a Nova clip may be a bit wide.....I have one in my 51 pickup, and it's just barely narrow enough for it. I would think a 30s car would be narrower......Of course, wheel offset may help too.....I may be wrong.
Old 05-18-2005, 08:54 AM
Wiki Edits: 49
You're probably more right than wrong. The best solution might be a Mustang II IFS but if his frame is rusted through in critical mounting areas he might have to look for one of the commercially available Mustang II compatible clips in order to do the job safely.
Old 05-19-2005, 07:12 AM
Last journal entry: Robs34 - Done my dash
Keep it
Welcome to the board.
First up, most frames of that era used the inverted channel method as a strengthener. Most builders ditch this part and box the inside of the rail in its entirety. The reason is that you will likely need to remove the old x member anyway for clearance of late model trans and running gear and make your own x member.
I would tend to retain the stock frame rails up front as in most thirties cars the front sheetmetal, radiator etcetra relies on the frame for location. Believe me it is easier to set up a suspension swap than rehash the entire sheet metal mounting.
For a suspension donor I have used Toyota 2wheel drive torsion bar set ups on Fords and Chevys of this era. The Toyota is almost perfect in width, has nice disc brakes and a Ford bolt pattern. I could adjust the bars so that the nose of my 34 roadster was 2 inches off the ground !
To install: The front frame member is cut out of the donor as aframe from behind the torsion bar , then the new crossmember has a rectangular hole cut on either side to the dimension of the rails where the crossmember will end up, and is slid onto the frame; bit of mucking around now; dummy the front fenders back in place and make sure the wheels are positioned right - you should have set the ride height up before now.. Use a datum point (the front perch of the rear spring is a good one on GMs) from the back of the frame on either side then measure diagonally to be sure that both sides are the same on either side so that it can be slid over the rails to the ideal position ( of course the front tie bar has to come out) after a bit of positioning, (I usually sneak the front axle forward an inch so the wheels are more centred in the opening); The torsion bars are then slid in and in most cases the rear torsion bar crossmember can be trimmed a little and re used, then with some 3mm plate the new front end is tied into the old chassis.The radius struts are reversed and a simple mount is made off the frame rail. Now you have a strong cool looking independant front suspension which fits under your fenders and can get you low! I will try to organise some pics of this swap and send them to you, I need to get the pics scanned and once I do that I will send them on.
Old 05-19-2005, 10:45 AM
Huckster's Avatar
Thanks Rob and all. I would like to see the pics when you get them scanned. Getting info from people who know what they are doing is going to make this easier that floundering around helplessly on my own.
Thanks again
1954 AD Lover
Spark plug recommendations Palmer Engine 2 04-10-2005 08:34 PM
Ingersoll Rand Compressor Recommendations daveh Garage - Tools 8 02-02-2005 02:38 PM
OEM brake hose recommendations powderbill Suspension - Brakes - Steering 1 01-14-2005 08:57 PM
Master cylinder recommendations wheel-7 Suspension - Brakes - Steering 3 11-04-2004 02:43 PM
Has anyone used this or have any better recommendations (breathing apparatus?) senor_limpio Body - Exterior 3 09-23-2004 12:23 PM
