Recommendations for a blown 383 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2008, 12:30 AM
I am just about done putting together my engine.I could use some recommendations on inital settings ( jetting,spur gears,etc.)for it and what you think of the combo.Its going in a 1924 Model T C-Cab truck. About 2400 lbs. street driven steet rod and not a trailer queen with ocassional crazyness at car shows.
GM 4 bolt main block punched .040 over,Arp main studs,line honed,decked,lifter bores trued.
Forged Diamond pistons dished -27cc ,moly coated skirts,ceramic coated tops.
deck height .010
Cometic head gaskets .041 comp height, 4.165 bore dia
Arp pro series head bolts.
eagle esp 5.7 H beam rods with ARP L-19 bolts.
eagle 4340 forged std crank. 2 peice seal.
Clevite H series main and rod bearings
Dart Iron Eagle heads 72cc, 2.080 int/1.60 ex ,215 runners, ported and polished on ex side,.straight plug
Crane 118571 solid roller cam dur at .050 232int/240ex, lsa 112, advertised 286int/294 ex. .gross lift .525 int/.543 ex.
Jesel SS shaft rockers 1.65 ratio both int/ex.
Jesel SBC Belt drive.
BDS 6-71 no teflon strips, but recently redone by them. 3" belt
Blower hub
2 Holley 750 double pump, mec secondaries. not four cornered.
Holley black fuel pump 120 gph with mallory 4 port bypassing reg.
NOS blower nitrous plate with 16 nozzles and seperate fuel pump and reg
Msd 6al with MSD billet dist, mech advance and MSD Boost time master.
TH350 trans w/2500rpm stall.
Frankland quick change rear. 4.86 ring gear. no spur gears yet.
27.5 x 10.50 x 15 tires.
Any recommendations,Honest opinions,critizisims, or am I out of my mind welcomed for jetting.timing,gearing etc would be appreciated or any thing I be missing.
Old 04-14-2008, 12:37 AM
additional items
Static compression ration of 8.15 to 1.
running on 92 octane on 6 lbs boost on street
with change of boost press to 12 lbs max and higher octane fuel for exhibition use.
Old 04-14-2008, 11:59 AM
BORTI's Avatar
BLOWN 357
Blown 383
That thing is going to be an E ticket ride.I have a blown 350 in a 3400lb el camino making 7lbs of boost and its a handful.With your setup you shouldn't need more than a 3.73 ratio.That motor will probably push 700hp.
I want more power on blown 383 smokin63 Engine 5 03-04-2008 08:19 PM
Chevy 383 - Heads and cam - recommendations? canter Engine 18 09-02-2005 04:29 PM
Blown 383 1980 Malibu Engine 9 08-22-2004 05:34 PM
Initial startup - blown 383 blown81 Engine 16 05-08-2004 03:37 PM
supplemental fuel injectors for 383 blown chevy stroker 383 Engine 8 03-24-2003 02:18 PM
