Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - recommendations on good but cheap metal fab tools
Old 01-05-2013, 07:23 AM
Old Fool's Avatar
Old Fool Old Fool is offline
The HF or any of the similiarly built ones NEED to be reinforced before they are worth $.02. They will spring under very little pressure. I reinforced mine with 2"x1/4"wall square tube. Still not rock solid but more than adequate for most usage.
Next, drill and tap the 4 blocks the shafts run through and install grease zerks. Otherwise it wont be long until the blocks and shafts are wearing each other out.
The Following User Says Thank You to Old Fool For This Useful Post:
tech69 (01-05-2013)
