Recommended ATF 1985 700R4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2004, 08:39 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
I am getting ready to install my beefed up 1985 700R4. Should I be using Dextron II or Dextron III. The re-builder mentioned Trick Shiftwas used to soak some parts, and I believe that is Dextron II equivalent.
Thanks,
Bob
Old 11-12-2004, 08:45 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
Use Dextron III. I believe Trick Shift is equivalent to Dextron III. Dextron III is an upgraded version of Dextron II. Dextron II is being phased out by the way.
Old 11-12-2004, 11:35 PM
Last journal entry: The floor going in
nice motor
i am doing an anglia my self with a 350 and 700r4 do you have any more build up pics and what chassic are you using?
cheers stuart
