Recommended Gun for Shooting SPI Universal Clear??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2012, 10:41 AM
texastomeh's Avatar
I know that threads re spay gun recommendation have been done to death and after reading dozens of them, I am more undecided than ever.
(1) I am a DIY hobbist - NOT a pro;
(2) Will be shooting three cars at most, spread over a couple of years;
(3) Soliciting recommendations re the best gun (and tip size) FOR the PRICE to shoot SPI UNIVERSAL CLEAR COAT ONLY;
(4) I stress again that THIS GUN AND TIP will be used ONLY be shooting SPI UNIVSRSAL CLEAR COAT;
(5) I am more than willing to pay the price for a GOOD gun, but do not want to "overkill".
(6) I know that the final results are mostly dependent on the guy using the gun, but I also know and believe you guys when you say that using a good paint in a good gun gives better results;
(5) I would also be greatly appreciative of any and all advice/recommendations re air pressure, reduction, flash time, compatibility, etc. based on your actual experience, that you would be willing to add in addition to the EXCELLENT instructions and information that Barry K. already provides in the Tech Sheets and on the outstanding SPI website.
I would appreciate any and all help.
Tom
Old 09-24-2012, 08:12 PM
novafreek6872's Avatar
Nova Guru
Honestly, and I may get flamed like crazy for this, the $35 HF Purple gun. I think its #66222 or something like that. Take a look at this video, new gun, WO fluid, WO fan, 45psi trigger pulled. Single Stage Acrylic Urethane from Summit. 3 wet coats.
http://youtu.be/q8D9F6ngRuM?hd=1
Andy
Old 09-24-2012, 08:20 PM
I used one and the results where quite surprising it actually came out good
Old 09-25-2012, 05:39 AM
deadbodyman's Avatar
Wiki Edits: 11
any gun with a 1.4 tip,Pros NEED good guns for using everyday ,Its a thick clear so start around 40psi and keep raising the pressure until it sprays like glass and hope your compressor can keep up, thats how I do it
Old 09-25-2012, 06:05 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I like my HF purple gun..I do have some others which do well also but the purple gun gets used more..As long as you have a 1.4 tip the SPI will make you look good..
Sam
Old 09-25-2012, 12:58 PM
texastomeh's Avatar
Can/will anyone share any comments or knowledge re either of these setups from Spray Gun World?
EuroPro HVLP
EuroPro HVLP
Thanx,
Tom
Old 09-25-2012, 01:05 PM
put up or shut up
devillbis guns are quality guns for cheap. I'd look into those guns in the $250 range. Most guns recommended would be good for atomization but the main question is, what kind of painter are you? Do you want fast strokes (1.4 tip) or do you want a slower more forgiving gun that's harder to run(1.3 tip)? This is yet another question to ponder before purchasing. Good luck and my recommendation is to look at the devillbiss line of guns and ask around about them. Nothing is as good for as cheap. Also, sharp finex isn't that bad for a guy that's only gonna use it a handful of times.
Old 09-25-2012, 01:30 PM
Irelands child's Avatar
I have a Devillbiss Finishline lll for an all around gun and when I don't want to do a full blown cleaning job on my Iwata. You can get 4 different tips and I have all - and have used that gun for everything from lacquer primer (yuk!!) to polyester spray filler and everything between. Works great and have ~ $200 invested for a quality gun. The HF purple guns - work well for some folks, but not me so will not recommend it - it's also, an air hog which means lots of overspray which means wasted paint - my shop has a fair amount of paint speckles from my experiences. Astro also makes a fairly good gun in the $70 +/- range.
Old 09-25-2012, 05:34 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
I would maybe try one of the cheaper guns untill you see if paining is something you want to do. You can always turn it into a primer gun later if you want to buy something more expensive, I just got a awtia 400 that works great but was over $600. Look at it like you would going deer hunting just because you bought the best most expensive gun there is dosen't mean your going to bag the biggest buck in the woods.
Old 09-25-2012, 08:14 PM
try one of these
CAT spray guns
Old 09-26-2012, 04:46 AM
Wiki Edits: 11
I used a gun with a 1.4 tip to spray base and SPI uni clear for years Then I got a deal on a nice gun with a 1.3 tip and although it saved a lot of base material it wouldnt spray the SPI uni clear well at all so the best all around tip would be a 1.4....
When I was starting out you wouldnt believe what crappy guns I used and got great looking jobs with so it really dont matter if your only using it once in a while Oh yeah all those guns were syphon types too.I was probably one of the last hold outs to use a gravity gun with the cup on top ,they just looked funny to me and I never thought they would catch on ,I've only been using them for about 1o yrs.
Old 09-30-2012, 12:20 AM
texastomeh's Avatar
Thanks for all the comments, recommendations and advice!
I've decided on the IWATA LPH400-LV gun with the Silver Air Cap. It is overkill and I will probably never do it justice, but figure "what-the-H*LL" - at my age I feel that I deserve it, so I'm gonna' "treat" myself!
At least I will not be wondering if I could have done better with a "good" gun!!
Thanx again,
Tom
Old 09-30-2012, 05:52 AM
Thanx again,
Tom
You WILL be happy with that gun - and if you groan later at the cost, just remember, you can't take the bucks with you anyhow. Some relative's greed wont let that happen
DW
Old 09-30-2012, 07:49 AM
boatbob2
Spray Guns.........
Hi,i use a HF ,HVLP purple gun,its about 6 years old,and it sprays EXCELLENT,minimal orange peel, love it...
Old 09-30-2012, 09:47 AM
texastomeh's Avatar
Could not agree with you more!!
The way that I'm looking at it is that our Daughter, Son-in-Law and Grandkids bought this for "Grampy"! (LOL)
BTW: I have a couple of the HF guns that I use for Primer and Base Coat. I have "opened up" the fluid nozzels a little to make a 1.6, a 1.7 and a 1.8 depending on what I'm trying to shoot. I've also got a HF 2.0 Siphon Feed Gun that I LOVE for heavy primers. I try to NEVER cross-contaminate the guns. At the prices of the HF stuff that's do'able. That's why my "plan" is to use the IWATA for ONLY Clearcoat.
Thanx again for all the help.
Tom
Cutting SPI universal help SoCal66 Body - Exterior 4 02-03-2012 09:46 AM
Gun selection for shooting high solids clear 67Elcamino Body - Exterior 38 12-07-2011 06:15 AM
SPI Universal clear CJ Runner Body - Exterior 7 06-27-2011 11:40 AM
SPI Universal clear....WOW mr4speed Body - Exterior 25 06-12-2011 01:41 PM
SPI Universal Clear: Runs???? off2wildblue Body - Exterior 14 04-28-2011 02:15 PM
