Recommened Tire Pressure?
On my 2001 Chevy Malibu, what is the best reccommended tire pressure to go by? Is it the pressure on the side wall of the tire itself, or by the sticker on the inside of the door jamb.
This of course is for aftermarket tires, not factory tires. I have Goodyear Aquatrea III's. They are the same size as the original tires. On the side of the tire is printed Max 44PSI. And, on the door jamb it says cold pressure 29 PSI front, and 26PSI rear. I want to keep these tires as long as possible, so I'm trying to find that sweet spot for tread life. Any suggestions? Chris |
Yea, the tire pressure listed on the tire is the max pressure the manufacturer recommends they can be inflated to safely. The tire inflation recommended by the auto manufacturer is a balance between handling and soft ride. They will usually set it lower to get a better ride. I like to set pressure at 35 front and 30 - 32 rear. Use a tire depth gauge to monitor tire wear and adjust as needed.
I could care less about ride quality. I honestly like it a little rough, the ride in the car that is. I think I to will be going to up the pressure to 35 and 32, that sounds pretty good. Thanks guys.
Chris |
I'd think if the max pressure is 44 psi you would the pressure to be closer to 40 psi. I would be afraid 32 psi would be too low and take a toll on the outside edges of the tire. Just my opinion.
Allot of the newer tires have higher recommended pressures. Most that I have seen are 44 lbs. Don't know why, but I always go by the recommended max on the sidewall.
Ontario Rodders |
I dont have a problem with the higher tire pressure if you want to go there. Thats why I said to use a tire depth gauge. If you wait and watch the tire wear its too late and you already have excessive wear. Record the depth of the tire tread in the center and the edges when its new. If the pressure is too high the center will wear prematurely. Rear wheel drive cars set the rear pressure a few #s higher than front wheel drive cars. MFG tire recommeded tire pressure doesnt take into account driving conditions, hilly and curvy roads vrs more straight driving.
I just adjusted my tire pressures up from 32psi to 37psi (2.5bar)and have noticed improved handling.The steering feels lighter, before I could feel the resistance when turning.Also the fronts were wearing on the edges. A higher pressure is less rolling resistance and better "mileage".
I run 225/60 15 on the front and 245/60 15 on the back. |
You don't have that much of a center contact patch, so adding pressure won't likely increase handling too much. I have EAGLE HP's on my Eclipse and they have a 44psi max rating also. I keep mine around 46 just to keep the wear in the center of my tires. They always lose pressure over time and it balances out my surface wear nicely.
If you ever tend to floor it on the highway, more pressure is ALWAYS safer than less. You don't want the friction of saggy rubber building up heat at high speeds. Keep it tight. I wouldn't go any higher than 48. Just watch the sharp looking potholes, they don't get along well with a high psi tire. MoocH |
| Recent General Rodding Tech posts with photos |
