recording sound of Rhoads lifters ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2005, 10:53 AM
With so much discussion of Rhoads lifters- and everyone trying to determine if they want to use 'em, and put up with the "noise". Why hasnt anyone recorded them and posted a wav. file ?? does anyone know of such a post? I have searched for it and cant find anything !? I understand it may be hard to discern the ticking from all of the other underhood hooliganism, but with all of the debate, if I were using them- Id record them, and set up a website that charged 1.00 to download the file. I'd make a million dollars !! (hey- if anyone decides to do that- i need some royalty $$, ive got that idea registered,trademarked,patented and photocopied ) .
Old 12-30-2005, 11:29 AM
larryblack's Avatar
Certified Lead Foot
Rhoads lifters are no more noisier than solids.
IMO the objection on the "NOISE" they make is more urban legend, embelish the story as told by those that NEVER heard a set running, but their "buddy has and he said they are loud" crowd. Typically a cam that truly benefits from Rhoads lifters is in a rather loud vehicle any way.
If you do not want to hear the lifters click, just turn the stereo volume up a bit.
Old 12-30-2005, 12:11 PM
sbchevfreak's Avatar
Licenced Automotive Technician
Or get on the loud pedal harder! You'll never hear 'em over the pipes and the tire squeal!
Old 12-30-2005, 12:58 PM
FYI, those lifters are not recommended for extended driving periods.
I feel that if someone whats a better idle then get a smaller cam or a cam with wider lobe seperation.
Old 12-30-2005, 01:07 PM
I had a set of Rhoads lifters in a 385" SBC that worked very well. I put over 30,000 miles on the motor without any problems at all, driving for extended periods of time. They cause a slight valve tapping sound like a solid lifter and the volume is somewhat dependent on the oil viscosity and temperature. Once you get above 3000 rpm or so they are as quiet as any other lifter.
Old 12-31-2005, 03:42 PM
I appreciate the replies so far- but I guess noone has heard /found any site that actually has the sound? Im pretty sure I can imagine what they sound like- a soild lifter cam, or rockers with too much lash. Just amazed noone has tried to record it and post it. Thanks for the replies though.
rhoads lifters 82c10 Engine 9 02-23-2010 04:53 AM
Re: Rhoads Hydraulic Lifters thenige Engine 3 01-25-2005 05:58 AM
lifters won't stop ticking - help Litdave Engine 6 07-24-2004 11:50 PM
Rhoads lifters dgkipp Engine 8 12-13-2003 02:22 AM
Opinion on variable lifters, rhoads type propaniac Engine 8 08-29-2003 10:53 PM
