Recovering "pillow-top" seats - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-05-2010, 11:02 AM
I'm looking at using a set of 1980s-vintage GM seats with "pillow top" cushions on a project. I want to eliminate the pillow top look and just use the seat frames and foam. Is the foam below the pillow portion the same thickness as on normal seats, or do I have to build it up to replace the thickness of the pillow portion? Thanks.
Old 09-05-2010, 11:06 AM
LATECH's Avatar
Last journal entry: New Gas Tank
Not sure about size of "bun" as it is called. I immediatley though about the density of the foam used for the pillow and the bun though.Thought it was worth the mention.FWIW.
Old 09-06-2010, 07:37 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Are these the kind of seats you're talking about? No, the thickness of the foam on the seat without the pillow top would be too thin to use by itself. Add enough thickness to bring the seat back up to the height of the original.
ID:	47926   Click image for larger version
recovering seats 79 Cruising Interior 26 09-28-2010 07:02 AM
recovering original Model A seats phantomgas Interior 1 05-15-2009 06:33 AM
Recovering seats daoldbuick Interior 2 05-05-2006 12:08 PM
Titanium Vavles w/Iron Seats?? Delirious2000 Engine 5 02-19-2006 09:58 PM
Which Racing Seats Should I Get? nightrain_rod Interior 7 04-08-2005 09:40 PM
