-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   recovering with vynl (http://www.hotrodders.com/forum/recovering-vynl-63991.html)
alden 06-08-2005 10:41 PM
I'm not sure if any of you guys are experienced with vynl but I thought I'd pose this question anyways. My glovebox came with a nasty tweed fabric on it (factory) and after 12+ years it was quite dirty and needed to go. I pulled it all off, and what was left was the bare plastic plus a bit of fuzz/glue.
I proceeded to recover it with vynl from a local fabric store, and I'm pretty pleased with the results, but one issue I had was around the handle. I had to cut the fabric to get it to go down in the pocket, resulting in small gaps where there is no vynl. Is there a better way to go about this?
thanks for any thoughts,
alden
here is the picture of the final product of my labors:
http://amackie.com/93240sx/glovebox.jpg
bluebu 06-09-2005 05:57 AM
I can't tell from the photo how deep the recess is for the latch but you might want to try warming the vinyl. A hair dryer or a heat gun, used VERY carefully, will soften the vinyl up enough to give it a little stretch. When I use vinyl I always lay it out in the sun for a bit before I start. The stuff is just much easier to work with generally if it's not cold.
