Red light on in 67 Camaro - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2008, 06:59 PM
So driving home the other day a little red light comes on right between the speedometer and the gas gauge. I never even noticed that there was a light there before. I thought it might be a low fuel warning light, but I filled it up and it's still on. Oil is fine, alt is good, coolant is good.... What other sensors did they have in 67??? Can anyone tell me what this light is???
Thanks Guys....
James
Old 08-04-2008, 08:31 PM
Semper Gumby
Wiki Edits: 2
Red lite
Possibly the brake warning lite? Just a thot.....
Old 08-04-2008, 09:23 PM
My truck has a brake warning light that is connected to the proportioning valve. If the pressure is too uneven between the front half and the rear half of the valve, it trips the switch and turns on the light.
When my warning light started coming on every once and a while it turned out to be a leaking wheel cylinder on one rear brake drum. I had to hit the brakes fairly hard before the uneven pressure turned on the warning light.
Bruce
Old 08-04-2008, 10:27 PM
It's the high beam indicator!!! Duh... I very rarely drive the car at night, and haven't outside the city, so I've never hit the highs... Must have bumped the switch when I was working on it last.....
Thanks for the input though....
67 camaro Pats67camaro Introduce Yourself 3 07-04-2009 08:59 PM
Front seats in 67 camaro ernkazern Interior 5 10-03-2007 01:45 AM
67 camaro rally stripes 67goat Body - Exterior 2 06-22-2005 05:22 PM
Yep! I'm new 2.... Pro-Touring a '67 Camaro L8model Introduce Yourself 6 12-09-2004 12:30 PM
67 camaro fenders are they all the same? roys63 Body - Exterior 9 06-18-2003 08:04 AM
