red scuff pad trick for newbes
I'am sure all the pro's on here has done this with a scuff pad but thought maybe some of the newbie's may not of tried it. Have you tried to scuff the underside of a new hood or trunk and cussed at how beat up your hands where when done? Well take two or three red scuff pads. Cut them in two pieces. Then install them on a 1/4" long bolt with some flat washers off setting each pad a little as you put it on the bolt. then lock it down with a double nut and lock washer. Now install into your air drill and your set to go. You can scuff until your hearts content and no more beat up fingers.
