Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - red scuff pad trick for newbes
Old 06-26-2012, 02:23 PM
swvalcon's Avatar
swvalcon swvalcon is offline
Last journal entry: rust on lt body shell
Thats a old body guy trick. If you take your old grinder disks and cut them into a star shape one size smaller and use a smaller backup pad behind it. Not only do they grind better they don't run as hot. You use to be able to buy a bench top cutter that would cut them down that way.
