Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - red scuff pad trick for newbes
Old 06-26-2012, 09:21 PM
S10 Racer's Avatar
S10 Racer S10 Racer is offline
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Originally Posted by swvalcon
Thats a old body guy trick. If you take your old grinder disks and cut them into a star shape one size smaller and use a smaller backup pad behind it. Not only do they grind better they don't run as hot. You use to be able to buy a bench top cutter that would cut them down that way.
Yeah, you're right, a star shape, not stop sign. We had the cutter but we usually just used tin snips to cut the disk and took a guess at it.
