Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - red scuff pad trick for newbes
Old 06-27-2012, 05:46 PM
swvalcon's Avatar
swvalcon swvalcon is offline
Last journal entry: rust on lt body shell
Another little trick is if you get some adhesive on a fresh paint job like weatherstrip adhesive and you can't remove it with anything because your afraid it'll take off the paint. Take a soft rag and wet a little of it with w-d then rub the glue with it and it will take off the glue without hurting the paint.
