red scuff pad trick for newbes - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2012, 12:24 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
I'am sure all the pro's on here has done this with a scuff pad but thought maybe some of the newbie's may not of tried it. Have you tried to scuff the underside of a new hood or trunk and cussed at how beat up your hands where when done? Well take two or three red scuff pads. Cut them in two pieces. Then install them on a 1/4" long bolt with some flat washers off setting each pad a little as you put it on the bolt. then lock it down with a double nut and lock washer. Now install into your air drill and your set to go. You can scuff until your hearts content and no more beat up fingers.
ID:	66312   Click image for larger version
ID:	66313   Click image for larger version
ID:	66314   Click image for larger version
Old 06-25-2012, 08:30 PM
Jimbo17's Avatar
Nostalgic Racing Decals
Neat Trick!!!!!!!!!!
Sure beats the old way of killing your fingers.
Many thanks Jimbo
Old 06-26-2012, 07:48 AM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
That's an AWESOME tip! Thanks for sharing!
Old 06-26-2012, 12:45 PM
cyclopsblown34's Avatar
Colorsanding painter
Excellent idea. Thanks a bunch! I thought I was onto something using them with my D/A with hook n loop fasteners.
Old 06-26-2012, 12:59 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Great idea. I use to work in a body shop back in the 80's and we used a trick to help remove the paint down in the bottom of a crease. We would cut old sanding disks in the shape of a stop sign. The points that were left would reach down in the crease.
Old 06-26-2012, 02:23 PM
swvalcon's Avatar
Thats a old body guy trick. If you take your old grinder disks and cut them into a star shape one size smaller and use a smaller backup pad behind it. Not only do they grind better they don't run as hot. You use to be able to buy a bench top cutter that would cut them down that way.
Old 06-26-2012, 09:21 PM
S10 Racer's Avatar
Yeah, you're right, a star shape, not stop sign. We had the cutter but we usually just used tin snips to cut the disk and took a guess at it.
Old 06-27-2012, 04:46 PM
swvalcon's Avatar
Another little trick is if you get some adhesive on a fresh paint job like weatherstrip adhesive and you can't remove it with anything because your afraid it'll take off the paint. Take a soft rag and wet a little of it with w-d then rub the glue with it and it will take off the glue without hurting the paint.
Maroon scuff pad to prep clear coat 67Elcamino Body - Exterior 4 06-03-2012 11:15 AM
GM bright red and flame red the same? Rosewood Body - Exterior 5 04-11-2010 02:09 PM
Wool Pad/Foam Pad/Products/whats ur Flavor BondoKing Body - Exterior 19 12-20-2005 12:30 AM
Scuff pad-gray or red jcclark Body - Exterior 4 05-11-2005 05:13 AM
Viper red vs. PPG bright red differnance? zachscc Body - Exterior 0 11-14-2003 10:54 PM
